1 - 20 of 23 Posts
hey there. I'm in a spot of choosing gogles for the first time, and as always with gear, I'm surfing around, reading about various goggles manufacturers and models, trying to get as much info as possible about them..
I narrowed my choice to Thor's Hero goggles and Oakley Crowbar MX goggles.
Thor
https://www.chainreactioncycles.com/Images/Models/Original/73962-1.jpg
Thor's have cool looks which I like and will probably get that mirrored lens which will probably make me look like an alien :D have to find out what that lens actually do - are the just for bright sunlight or can work in wintertime as well, with not so much sun and with grey weather (anybody?). was reading about them and people say they may fog sometimes, but as soon as you start riding they clear (from what I gathered, most of the goggles have that 'feature').
Oakley
https://www.chainreactioncycles.com/Images/Models/Full/16131-4.jpg
on the other hand, Oakley's have cool looks as well, and they have great selection of aftermarket lenses which I like. will probably get couple of those to have a wide selection of lenses to put according to weather conditions..
if you have any info/thoughts on these two, please, let me know.
if you have some other goggles you think I should consider and look into, I'll take your advice and check them out.
thanx!
I would try to find a mx shop and try them on. Every pair of goggles fits differently. When I was on the search for snowboard goggles i tried on at least 10 different pairs of goggles for fit then found a color scheme that i liked in that goggle. This is not to say you won't get lucky and have them fit perfectly its just that the odds are against you.
Wish i could provide insight as to which will work better but only YOU can tell that as far as fit goes.
As far as lenses any light colored lens will work in winter (the lenses on those thor's looks like they would work fine)
Picture Unrelated
Well, for what it's worth I have the Oakley Crowbar MX (and a couple pair of snow Crowbars) and I really like them. But more to the point, even other Oakley goggles don't fit my face well and you never know how a goggle will interface with your helmet until you try. The try on is key to buying a goggle. With the MX goggles, they're mostly the same technology so what you should be looking for is fit and a lens color that you like.
I've just got a light blue lens for my goggles and they're good in low light and good enough in bright light. I find the mirrored lenses vary wildly in quality and color. Some of the ones that appear totally opaque are very lightly tinted and some are so dark you can hardly see out of them. Oakley has a light transmission chart and simulated images for lens colors that can help give you an idea of how much light a lens lets in. I've now rode with clear and blue lenses and I don't think I'd go much darker than that unless I were riding exclusively in the unshaded sun which really doesn't happen, but that's just me.
Like others have said, try on as many goggles as you can to see how they fit your face and helmet.
If I can add one to your list of goggles to look at, it's the Progrip 3400. I love the feel of my Progrip goggles, and especially like the light sensitive lenses. Mine don't fog up too bad, and the lens seems to change from light to dark and back to light pretty much instantly in relation to light conditions.
Discussion Starter · #10 ·
thanx dude.. will give it a look, for sure!
Discussion Starter · #13 ·
i went for Oakley O Frame MX goggles in red and have been very happy, they have tear off towers and replaceable lens' should i feel the need or mark my current lens.
I also use Oakley for my snowboarding Goggles.
thanx for the tip.. I think I'm gonna go with O Frame MX as well... what lens you use now? clear, I suppose..
one more thing for all you guys here - are dual vented lenses that much better than normal? because they cost 3 times more....
yeas they are worlds better with fogging, thats why the dual layer lenses are used in snow sports.
as for cost $20 vs $8 i would say its worth it. (check the llinks)
nwmlarge said:
i don't think dual vented can be replaced
yes they can, same method as single layers
dual vented
single layer
Trail Ninja
Check out Zeal Detonators, if you have the cash. Absolutely no fogging on my set. They're meant for winter mtn sports, but works better than goggles I've tried for mtn biking. Wish the photochromic one went from clear (~90% light transmission) to its usual 13% (currently 43% to 13%), so I would be more willing to keep it on in the dark.
Discussion Starter · #20 ·
Zeal's are mega expensive - that Detonator model is cabon, right?
have to say I don't like those ski goggles, don't know why... and with that price tag, I'll skip those-like, at least for now.
I can imagine these work better for MTB, though, cause they're made for extreme temperatures, sure... and totally agree on that 90-13% thingy, defo...
1 - 20 of 23 Posts
