1 - 20 of 356 Posts
Let's get this going. This is a crazy adjustable shock, and everyone will have their own preferences based on terrain, etc. This is a good starting point based on our suspension design...
HSC: 1/2 turn from fully open (the 4x4 suspension design provides inherent bottom out control, so no need to over-damp this setting)
LSC: 15 clicks from fully closed (the 4x4 suspension design is FULLY ACTIVE, so a couple extra clicks from middle(12) keep the pedalling smooth and controlled)
HSR: 1.5 turns from fully open (rider preference prevails on this one, depending on how fast you ride and how big the hits are)
LSR: 12 clicks from fully closed (this is the median setting and keeps bumpy/technical climbing from feeling too springy)
Cheers.
Dusty thanks!
Question-
Why not do everything from open? Since everyone discusses in this manner and even cane creek has adopted the "from open" setting. This would provide consistency, as there are variances with respect to the total clicks and turns so a common start point would be ideal.
Just a suggestion...
Discussion Starter · #5 ·
Dusty thanks!
Question-
Weird. I literally took the language straight from their DBcoil base settings sheet, which must be a little dated I guess? Oh well. I agree, uniformity would help everyone.
For what it's worth, I just heard back form Malcolm and he sent me exactly what Dusty posted, word for word.
Dusty, are these settings what you are running, or have you tweaked them a bit to suit you personally? You told me the other day you got to that "I thought I had a flat tire feeling but it was just my shock tracking well" point on yours, and that's typically pretty indicative that you've got the settings pretty damn close to dialed.
Discussion Starter · #7 ·
Ya, I sent my settings to Malcolm right after I posted them here, they will be a good starting point for anyone, since they are fairly neutral yet specific to our suspension design.
I've been tweaking this shock for the better part of a month, and I let G-Air borrow it for a week for a 3rd opinion(Noel was the first opinion). These settings are the amalgamation of all this input.
DB Coil Settings?
Language aside, would these DB Air base settings be an accurate starting point if transposed over to the DB Coil? Or do these numbers pertain specifically to the Air model?
Odd thing is last year or so Malcolm told me to do everything from wide open, especially the low speed adjustments. He said from wide open, they are fully closed at 24 clicks, but due to the way they are made (no idea on specifics here), they can have 2 or 3 extra clicks. So from that, if you wanted to open it say 15 clicks, you might really only be on 12 or 13.
After talking to him, I just figured out what my settings where and recorded everything from wide open.
In short, no.
I found the air and coil to have quite different settings. The most noticeable difference was with the HSC. With the air I ran very little HSC. With the coil I was right in the middle of the adjustment.
Maybe Dusty can chime in. He has quite a bit of time on both shocks.
I picked up a DBair for my endo and noticed the same thing. The manual states that there are 25 clicks of LSR and LSC and I've found that number to be pretty accurate for my shock. The HSR seems to have almost an extra full turn (from the 4 that is stated in the manual).
I know this is the Chili thread but here are my settings for an older endo in case other endo owner's pick up a DBair.
LSC: 9 clicks from full open
LSR: 19 clicks from full open
HSC: 1/2 turn from full open
HSR: 3.5 turns from full open
Compression settings are similar to the posted Chili #'s but I seem to prefer slower rebound. Still dialing it in so the #'s might change a little.
That is a ton of HSR? Of the 4 CCDBs we have on our bikes (only one is DB air) I dont think any of them is past 1.5 turns (3 Knollys and 1 Turner). Different strokes for different folks I guess!
Buzz
Buzz
I agree - though the CCDB coil on my Podium has about 2 turns from open and that bike sticks to the ground.
That's the thing about CCDB so many choices:)!
Buzz
Yeah I was surprised where it ended up too. I may slowly back it off, but probably not too much. Right now it feels pretty good. The downhills I ride are pretty rocky and fast and the slower rebound helps the bucking. It will be interesting to see where others land on their adjustments. BTW, I'm running about 38-40% sag.
Yebo Numzaan
Sorry if i missed it - has anyone posted anything about how the DB air actually feels on the bike? I heard a comment y'day that you can still tell that its an air shock (vs a coil).
I have never heard that 'flat tire' comment before...sh1t...every time i get that feeling...i adjust something because i dont like it :(
Apart from all the settings - i would dig to hear some personal feedback.
thanks dudes
1 - 20 of 356 Posts
