Jenson Shoe Blowout!
Everyone likes the feeling of a crisp new pair of kicks, especially when they're on sale. Check out these hand-picked deals on everything from Five Ten Freeriders to Scott RC Road shoes. Look for great deals on waffle pattern grips and tools too!
FIVE TEN MALTESE FALCON SHOES
The Five Ten Maltese Falcon shoe is an optimized all-mountain shoe that flirts with the Enduro rider. The lightweight upper repels water and dries quickly in the wettest, muddiest conditions. The Maltese Falcon doesn't merely entail the looks of chic shoes, but utilize Five Ten's Stealth S1 compound on the rubber outsole to reduce vibration and chatter through the bumps at high speeds, making them just as ideal for hiking as they are pedaling through the windy single track. Lace-up the Five Ten Maltese Falcon and bask in comfort and performance on your next mud-filled escapade.
$64.95 SAVE 50 % MSRP $130.00
KESTREL LACE
The Kestrel Lace incorporates all of the success seen in the original Five Ten BOA Kestrel while delivering pedal efficiency and comfort in a classic lace closure. They feature stiff, nylon shanks that are designed for ultimate power transfer to the pedals and EVA midsoles for excellent shock absorption. The outsole is comprised of proprietary dual-compound Stealth rubber. Where the pedal meets the shoe, the Kestrel has C4 Stealth compound that increases power transfer and durability so you can rip-it-up, without actually ripping them up.
$74.99 SAVE 50 % MSRP $150.00
GIRO PRIVATEER R HV MTB SHOES
Here's Giro's classic trail shoe, improved. The PrivateerR features a new nylon and rubber co-molded outsole for durability and improved grip on rocks or roots. The reinforced toe box has a rubber toe-guard for improved durability but stays comfortable with a supple microfiber upper, two straps, and a micro-ratcheting buckle. The stiff nylon outsole helps create a shoe that matches the performance of more expensive composite designs. Other highlights include aggressive lugs for improved traction, toe spike compatibility and a supportive EVA footbed with Aegis® anti-microbial treatment.
$99.95 SAVE 33 % MSRP $150.00
FIVE TEN FREERIDER ELC SHOES
Five Ten's Freerider ELC shoes are meticulously crafted to reach peak altitudes of awesomeness. The Stealth Phantom outsole features classic Dotty tread, giving these shoes an affinity for gripping pedals. The leather and synthetic upper mold are polyurethane coated to keep mud and water from turning your feet to prunes. The ELC also has a stiffer midsole than the original Freerider, making the shoes extra supportive. A leather lace cover serves to protect your laces and keep them from snagging on sneaky roots. These shoes offer ample protection and support for aggressive free-riders, and they do it all at under 500 grams each. (Size 9 US)
$69.95 SAVE 50 % MSRP $140.00
SMITH ROUTE HELMET
Smith's Route helmet combines the latest in protection technology to give riders unmatched comfort and protection, begging to be tested in a variety of cycling disciplines. The Route is comprised of Smith's tested Aerocore construction, then sealed with a Koroyd shell to hone in on vulnerable impact areas. The finished product offers excellent protection, proper comfort, and optimal ventilation. Great for warm rides, the AirEvac and VaporFit systems assure that air flows efficiently and that the helmet has a comfortable and confident fit. The Route raises the bar in protection and versatility, satisfying whatever your rides demand.
$34.99 SAVE 77 % MSRP $150.00
FOUNDATION SHIMANO STYLE BB TOOL
Nothing drives a cyclist crazy like a noisy bottom bracket! Use the Foundation Shimano Style Bottom Bracket Tool to get in there and service the squeak out of your external bottom bracket. The shop grade Foundation Shimano Style Bottom Bracket Tool enables effortless removal and installation of Shimano Hollowtech II style bottom brackets.
$9.99 SAVE 67 % MSRP $29.99
VELO LOCK-ON HALF DIAMOND GRIPS
Comfortable and grippy, the Velo Lock On Half Diamond Grips will keep your hands glued on the bars and allow you to handle the trail with ease. The lock-on feature makes sure the grips don't slip even under the most demanding of rides.
SCOTT ROAD RC MEN'S ROAD SHOES
Whether you're leaving your stamp on the local crit series or KOM hunting in the mountains, Scott's Road Premium shoes feature a linear high modulus carbon fiber sole in a 10 ply layup, providing an insanely stiff launching pad that won't weigh you down. The MTB Premium shoes forgo the conventional ratcheting buckle and instead use an IP1 dial closure system at the top with two lower anatomic fit straps that articulate and conform to the shape of the foot. The result is a straightjacket-like foothold, without the irritating pressure points.
The asymmetrically conforming upper is constructed of microfiber air mesh, allowing air to flow efficiently throughout, while the ErgoLogic insole features adjustable arch support and Metatarsal button to reduce forefoot numbness and evenly distribute compression. This Arch adjustment permits proper foot alignment and allows adaptability to individual arch height and fit.
$139.99 SAVE 60 % MSRP $350.00
GIRO SENTRIE TECHLACE ROAD SHOES
Giro's rad new Sentrie Techlace Shoe offers elite-level performance with the comfort of laces and the convenience of a strap. Need we say more? The Techlace system replaces D-rings and other hardware with laces, providing a suppler feel across the forefoot, and the laces can be painlessly replaced if damaged. The Boa L6 dial offers 1mm adjustment increments when tightening and easy pull-to-release function for quick removal of the shoe. The Sentrie Techlace is constructed with a lightweight bonded and welded breathable upper and an Easton® EC70 carbon composite outsole. Inside the shoe, Giro's SuperNatural Fit footbed features adjustable arch supports to personalize fit, with excellent comfort and pedaling efficiency.
$149.99 SAVE 40 % MSRP $250.00
VITTORIA CROSS XM PRO II TIRE
Having a good set of tires can change the way your bike rides. Having the wrong tires for the terrain you're on could lead to performance issues. The Vittoria Cross XM Pro II tires are designed to be used in mud and soft conditions. With a lateral tread design, it helps to create traction in mud and soft dirt, and with wide knob spacing to help shed mud from the tires, you won't have to worry about the mud sticking. With 150 TPI, this will be a go-to tire for any racer or rider looking to have some fun in the mud.
$13.99 SAVE 67 % MSRP $42.00
