Seems like there was quite a bit of input on the "tubeless conversion" thread and no one bothered mentioning something that I thought everyone was doing. This requires no "trimming" or any other hassle that others are dealing with....and it's cheap!
This is my way of stickin' it to the man and making the system work for me:
Rim- WTB dual duty - probably the worst rim for running tubeless due to a deep interior with prevents the bead of the tire from seating
Tape- I used the stan's yellow tape because I had some left over from the stan's wheels I race on....but you can use the reinforced packing tape.
Tubeless rimstrip - 650 road tube - The best is the continental because it has a removable valve core. They only cost $4.00. And you don't need to slice it down the middle and trim it up to fit in the rim channel. Run an ultralight tube if you have a shallow rim channel....run a heavier weight if you need to take up some rim space in order to get the tire bead to seat.
Directions: cut a small hole opposite of the valve stem and lay the whole tube into the rim channel. Install your tire and inflate using your favorite sealant. The tube will flatten out into a perfect rim strip. Make sure your whole is not too large.
I've been able to run wire bead and foldable tires of various brands and I've had no problems.
Check out the pic.
Check out the pic.
