1 - 9 of 9 Posts
I have recently been getting into djing freeriding. I am planing on buying a cheap khs DJ300 frame and doing a frugal build up. I was thinking i would taking the drive train and fork of my spec rockhopper and use it for my build. With plans of upgrading things as good deals come my way or when things break.
http://www.specialized.com/bc/SBCBkModel.jsp?arc=2006&spid=21740&bikeTab=techspec
i would also want to imediatly upgrade to avid mechanicals, so i would need a new wheel set. can anyone suggest a cheap but good wheelset for me ?
does this sound like a decent idea ? are there any parts from my xc bike that just wont cut it for djing (besides the fork)?
thanks
h-town hucker
Azonic Outlaws
$250 for the set. front hub is convetable from qr to 20mm. you pick the spacing for the back wheel when you order them; 135mm or 150mm. i don't really understand what it means though.
40 oz to freedom
sandyP1 said:
Azonic Outlaws
The spacing is how far apart the rear drop outs are. 135mm is normal for MTB's. DH bikes and some Freeride bikes use a 150mm rear spacing. BMX bikes use a 110mm rear spacing.
You would want a 135mm rear spacing for your build.
Discussion Starter · #6 ·
bike looks great cant wait to get started.... does the dj 300 use qr or 20mm hubs ? Im guessing they are qr. and can anybody recomend a budget discbrake wheelset for me ?
thanks
40 oz to freedom
The dj 300 uses a normal qr, its the forks that use 20mm.
As previously suggested the Azonic Outlaws are great wheelsets. Jenson USA also has Shimano Saint Hubs laced to Sun Rhyno Lites. They are pretty decent wheels for only $169. You would need to run Saint Hydros, but those are awesome breaks. You would need levers, but I think any Hydro levers will work.
http://www.jensonusa.com/store/product/BR407C01-Shimano+Saint+M800+Disc+Brake.aspx
Or if you want to use different brakes they make an adapter that converts the center lock rotors to 6 bolt IS disc mounts:
http://www.jensonusa.com/store/product/BR605Z00-Problem+Solvers+Adapter+-+Ctr+Lock+To+Is.aspx
40 oz to freedom
My bad, the adapter DOESNT work with Saints.
But either way, the Saints are great setups if you want to spend the extra money on the brakes.
1 - 9 of 9 Posts
