I've got a 2018 RockShox SID World Cup with Charger 2 damper and remote lockout. It's been working just fine (brand new a few months ago) but, after a minor crash, seems to have lost all compression damping and lockout function. I'm not especially sensitive to damper settings, but the lockout was solid before and non-existent now.
On essentially flat ground, I hit a very square rock on the side of the trail due to tired legs and lack of focus and went over the bars very slowly, deeply compressing the fork in the process. I believe I had the fork locked out at the time, but maybe not. It was immediately after that when I noticed the lockout wasn't working.
I've tried releasing all air pressure (both positive and negative via "hidden" valve) and re-inflating. No change. With no air, it compresses all the way (full travel of 100 mm). No sticking or binding. There is 105 mm of exposed stanchion when fully extended (with no negative air pressure) and about 2.5 mm less when the negative air spring is filled (first compression of the fork). Before I press down on the fork the first time after inflating the positive air, the fork feels locked out but I'm sure that's just due to the lack of pressure in the negative spring. This all seems entirely like what I'd expect. Seems completely normal.
The remote lockout pulls the cable normally and holds the locked position just like it always has. I see zero evidence of any oil leak whatsoever.
The compression adjuster has about 19 indexed positions and there is no difference in performance regardless of the setting. I run it 8 clicks from closed.
The rebound adjuster seems to function normally. It has about 26 indexed positions. Rebound is definitely slower when the adjuster is all the way in than when it is all the way out. I run it 10 clicks from closed.
What is wrong with this thing and how do I fix it? When I open up the damper side, is there anything specifically to watch for that will help diagnose the problem? I have a bad feeling something blew out or deformed inside the damper and it's not user serviceable. Makes me miss my old Fox F100 with Stratos ID damper...
