This topic has been covered before...
Tubeless adds very little time to tire swapping. Most of the time added has to do with cleaning and installing of sealant, which is optional if you use true UST.
Ghetto tubeless is IMO not so good for people who like to swap tires around. Of course that depends on the method used. Gorilla tape or Stan's conversions are fine for tire swapping. The split tube method is not as good as the tube usually gets a bit mangled and hard to keep in the same position as it was cut to the first time. I usually only get 1-2 mounts out of a ghetto setup with the split tube before I need to replace the tube.
That said, the split tube method holds air better and is less prone to burping. It also works on a wider range of rims.
