1 - 9 of 9 Posts
yelgatgab
So, I been riding a Chameleon for 2 season and frickin love it. It does XC, DJ, freeride, you name it. The geometry is spot on, and it handles like a dream. There's one problem though. My old bones are getting beat up by this sooper stiff hardtail. I've messed w/ tire combos and air pressures, and the fact is, my body just can't take it.
I've been looking for a while for an FS "Chameleon", so to speak, and it looks like the Blur 4x might be the answer. The biggest problem that I can see is the head angle. SC's website used to list the Chameleon's HA as 69*, but now it's 69.7*. If that's the case, then I'd basically be going down 2 degrees w/ the 4x (4x has a 68.5* HA w/ a 4" fork, and I'd be putting an '03 Z1 FR on it).
Is there anybody in here that's ridden both bikes that can comment. I know the Blur LT is an option, but I really don't want/need that much travel or bike. I love the smaller, tighter package of the 4x. This bike would see 70% trail riding, w/ the rest being DJs and freeriding.
SS Pusher Man
The head angle would slack out a little more with a 5" Z1......not necessarily a bad thing. Plus you can lock down your fork for climbing if you find the head angle too slack for steep climbs.
mtnbikej
4x does everything well except downhill (not enough travel), and seriously it´s not going to be too slack unless you are a true xc rider who should be looking more towards something else. This bike was designed to do the things you listed, get a PIKE instead of the Z1 so you can run it steeper if you want. I`m of to ride mine now :) .
I have a Cham and 4x now
I only have a few rides under my belt on it, but my Blur 4x (large) rides really nice and I feel really comfortable on it already. I also have a Chameleon (medium) and the transition was really easy between the two. I've always had the Cham set up as a fun, bmx/street/dirt jumping bike and I set up the 4x as my main trail riding bike that can do everything (within reason, of course). I think if I was going for a straight replacement of the Cham, I probably would have gotten a medium 4x (I'm 5'10" BTW), but as it is the large w/ a 70mm (vs a 90mm on the Cham) feels really good. While the 4x does have a really slack headtube angle, I wouldn't worry about it much, unless you're looking for a bike to just ride/race XC on, which you said you're not. I think the 4x would really work well for what you're looking for.
Let me know if you have any specific questions that I can try and answer.
Chris
Dunno.... Haven't ridden a newer chameleon or compared the specs to mine. I know the seat posts are diffferent sizes, but I'm not sure if the geometry changed any between mine (an '02, I think) and the newer ones.
SS Pusher Man
sreiman said:
is that a 03 chameleon? does it ride differently then the new 05's?
I had a '01 Chameleon, '03 Chameleon(pre change) and now a '04 Chameleon. I can tell that there is a slight difference in ride quality.
The older Chameleons seemed to ride a bit smoother. YOu have a tendancy to run a lot of seat post on the Chameleon. When the seatpost diameter was 27.2 you would get a little more flex outta the post than you do with the newer 30.9 posts. Also the intersection of the seatstays and the seattube are quite a bit beefier on the newer models, so it seems a bit stiffer. Don't know if the gussets on the headtube make it ride any different. I have never run a fork longer than 130mm on one.
mtnbikej
1 - 9 of 9 Posts
