I ride an XL Burner (from the last year they were made, I think -got the frame when Supergo was closing them out with the Manitou Swinger on there). I have persistant chainsuck problems. Shifting up front from the middle to granny ring very often causes the chain to get improperly routed (it goes from the rear derailleur up above the chainstay and then down onto the granny ring; it happens when the chain fails to come off the middle ring quickly enough and ends up between the middle ring and the chainstay before the shift is completed). I can pedal like this, but I can't get the chain back out of there without getting off the bike and pulling it out. So far, I've:
-put on a new chain and a new middle ring (since that's the one it gets stuck on)
-adjusted the chainline (yes, I'm using the correct spacers for my bb)
-switched to Boeshield lube
I'm using a very old rear derailleur (XTR, pre-mega-9), and I'm wondering if that's failing to keep chain tight enough as it's leaving the rings. It might be a bit worn out/beat up. Still, it doesn't really seem like the rear derailleur should be the problem behind the shifing on the crankset. Do I need to use some kind of chain tensioner or retention system? It doesn't seem like it should be necessary. The clearance between the crankset and the chainstay is a bit tight, but the chain shouldn't be on the teeth when they're going past the chainstay anyway.
Let me know if you have any suggestions.
