1 - 20 of 26 Posts
Hello all,
I recently bought a bike off an auction site that was described as having wear from normal use.
Much to my horror I found evidence of pretty bad chain suck, and another patch of wear from unknown origin. It's this latter patch that concerns me. It seems to go a fair distance through the aluminium.
Is this frame toast?
Many thanks for any opinions you may have,
Harry
Yellow Fluid
Yellow Bicycle handlebar Bicycle part Green Bicycle accessory
Yellow Green Bicycle accessory Bicycle part Purple
since 4/10/2009
I would demand a refund from the seller. That is most certainly NOT "wear from normal use". I'm pretty sure that frame is f0cked. The bb shell is an absolute mess. The chainsuck looks awful, but mostly doesn't look deep enough to compromise much. The inside of the chainstay looks like tire rub, and that looks deep enough to be a problem.
The hell happened to that bb shell?
Yeah I'd be more worried about the tire rub on the inside, that is pretty deep. You would have noticed that rubbing... There is no situation I can see here where they didn't know it happened
If it was eBay it is as easy as filing a claim and stating the item was not as described. Clearly they failed to provide pictures of that damage or describe it. You will be covered.
Discussion Starter · #8 ·
Thanks blkangel
It was actually from a bike shop (selling thru eBay) but they were only 1.5hrs drive away so I went and picked it up. I complained and they said to "drop it off" and their mechanics would look at it, and if I'm not happy, give me a refund.
So unless their mechanics are going to replace the frame, I'll settle for nothing less than a refund...
since 4/10/2009
Thanks blkangel
I'd still file through ebay. reports like that go on their seller's record. you don't properly document stuff like that (because you know if you do, it'll affect the sale price), you need to be taught a lesson.
It's probably a bike that a customer dropped off for service and just left behind, and the shop is trying to recoup their costs on it. Which are probably higher than the bike is worth. I've seen that countless times.
Discussion Starter · #15 ·
One final advice request please!
I found another one which has this much damage. It was covered by a protector but I asked the seller to remove to have a look at it.
I imagine this scratch was done then the protector was put on which prevented further damage.
I think this will be absolutely fine, assuming it's re-covered by a protector. Yellow Engine Machine Nut Automotive engine part
Would you agree?
EAT MORE GRIME
(ノಠ益ಠ)ノ彡┻━┻
I think this will be absolutely fine, assuming it's re-covered by a protector. View attachment 1247151
Would you agree?
NO
those scrapes turn into cracks if you ride a lot
which turn into broken bike
it may last it may not. how much do you plan on riding ? a ton ? then no
that damage is unacceptable to me. ymmv
Personally i think that looks like a paint chip. I have had plenty of nicked up chainstays with zero issues.
Discussion Starter · #19 ·
NO
I'm a beginner! Recent convert. Spent the day on trails with a hired Orange Crush and loved it. Realistically due to heavy work commitments I'm not going to ride loads... probably 10-20 miles a week.
Discussion Starter · #20 ·
Hard to tell from that angle, is that the paint that's raised?
I think it's taken the paint off and will have scratched the metal a little - I imagine it's like 3 out of the 500 scratches that caused the damage in the first picture I posted of the other bike...
1 - 20 of 26 Posts
