Hi all, I've got a problem that's driving me wonky.
I upgraded my 8sp drivetrain to a 9sp XT front and rear, chain, cassette and shifters... everything but chainrings.
Problem is the front der... just doesn't move inboard far enough to shift to the small chanring. Even if I back out the low limit screw all the way, it's still not enough. With the shifter in low, the cable has slack at the der, so it's not a shifter issue.
I suspect it's the alignment of the der. but it's perfectly (within .5mm) parallel with the chanrings. Do 9sp chainrings have a different offset from the frame?
Everything else is working perfectly. Thanks in advance for any suggestions you can offer.
