Whats the largest chainring you can run with a straight chainline on a surly 1x1
Does Surly know?inkdwheels said:wow, nobody knows...
I am uncertain as to whether or not this is a definitive answer, but I have a 34T on mine and it is tight. My guess is that 36T would be the absolute max, but this is speculation at best.inkdwheels said:wow, nobody knows...
BB spindle length shouldn't make a difference as it will modulate chainline when modified, i.e. if your chainline is spot on with the rear hub, your chainring clearance is finite. You can run the chainline slightly off, but this tends to make noise and reduce the life of your drivetrain (often shaves the tooth to a smaller thickness).OneGearGuy said:BB width should be worth considering, too.
i'd go right to the source:
http://www.surlybikes.com/
OGG
...and rear wheel/chainline. Say you're running a converted cassette wheel with the cogs all the way outboard and the chainring on the outer position or BB with a long spindle. Surely you can use a bigger chainring than if you were using a SS-specific hub and single FW with a "standard" chainline.OneGearGuy said:BB width should be worth considering, too.
That's a good call.roadiegonebad said:...and rear wheel/chainline. Say you're running a converted cassette wheel with the cogs all the way outboard and the chainring on the outer position or BB with a long spindle. Surely you can use a bigger chainring than if you were using a SS-specific hub and single FW with a "standard" chainline.
