1 - 18 of 18 Posts
Mint condition '06 Cannondale Prophet 600
Discussion Starter #1
I HATE chainring nuts. Im converting an old bike to singlespeed, and to get the chain rings off i need a tool that I don't have and don't feel like buying, so im using a flathead screwdriver which barely works. I KNOW i won't be able to tighten the nuts when i put it back together. Should i buy a specialty tool, and what exact one would be good for it?
I also have a similar nut holding my derailleur hanger on.
Component companies did this just to annoy me. I'm convinced of this.
Thanks everyone
It's a type of low-profile sex bolt (look it up). Chainring nut wrenches are common at bike shops, and most have at least one for sale (if not a box of them, if they're an old shop).
Should they not be available, you can turn a large flat-head screwdriver into one by marking out a 3-4mm 'nose' in the middle, cutting two 1-1.5mm notches on either side of that, and removing ~1-2mm of height from the blade remaining on the shoulders.
The friction of the chainring nut in the hole is often enough to hold it in place while tightening, though--infrequently--you'll need a wrench to hold it in place. A finger is typically enough 95% of the time.
Impact guns usually loosen the nuts without spinning, and are the preferred tool when available (unless said nuts/bolts are expensive/irreplaceable).
Incidentally, if there is room for them (and there typically isn't on derailleur hangers), you can get double hex or hex/torx chainring nuts/bolts.
If they're already off and in decent condition you probably won't need a special tool to tighten them, just make sure the threads are clean and greased and they'll usually tighten up just fine.
A park chainring tool is only about $5 btw.
Yeah, a chainring nut wrench is one off those tools I use so infrequently, it is annoying to dig up.
To avoid buying a dedicated one, you could buy one of the more accurate go/no go style chain wear checkers with a built in chainring nut wrench for around $15. I picked one up without realizing it had this bonus tool built in:Chain Checker Plus II » Pedro's NA
Discussion Starter #5
Oof yeah $5 seems good. Ig the built in chain checker one is good too, thanks guys. I think i'll buy one. Seems cheap enough
Discussion Starter #6
if you have a bike that is using a modern cassette, you can buy one of the more accurate chain wear checkers with a built in chainring nut wrench for around $15. I picked one up without realizing it had this bonus tool built in:Chain Checker Plus II » Pedro's NA
Love your Kent Brockman profile pic lol
  • Like
Reactions: b rock
since 4/10/2009
I have all kinds of bike tools, and the chainring nut wrench has never made it into my shop.
When I needed such a tool, I always used a flat screwdriver. And then replaced with hex/hex or hex/torx chainring bolts asap.
Not possible with that hanger, though. I hate all the ridiculous proprietary hanger designs out there. I have a bike with a syntace hanger and it's so much easier to deal with (and is also the cheapest one to replace that I've ever had).
I seldom need one either but for those occasions when I do they're extremely handy and worth having in the box, especially considering how cheap they are.
Discussion Starter #11
Very rare that just jamming a fingernail into a groove to give it a bit more friction isn't enough. Last time that wasn't enough I found a old razor blade gave me just enough friction to get the nut undone. View attachment 1909753
That looks good, I think i'll do exactly the same
Cheap tool, but it's still a PIA to get them off even with the tool. I love the way Sram did it on some of their later triples. 6mm on the female side of the nut, 5mm on the other. EZPZ.
BOOM goes the dynamite!
Occasionally Cranky
Back in ancient times I used a dime - works slightly better than a fingernail, but that razor blade looks ok. Just don't slip.
:eek:
Murica Man
Do it for Dale (#3)
:eek:
lol, just use pliers
1 - 18 of 18 Posts
