I want to change out the 4 chainring bolts on the big ring to some blue ones. For some bling obviously. I've been looking at these. http://cgi.ebay.com/MOWA-CRANK-CHAINRING-BOLTS-5-PAIR-7075-BLUE-/200443629177?pt=Cycling_Parts_Accessories&hash=item2eab5f0e79#ht_4012wt_905 Mine just screw through the big ring into the middle ring. It's a hollow bolt ( no nut on the back). Will these work? What size would I need to get? There is no back to it, that some seem to have. It simply screws in.
These also.... http://cgi.ebay.com/Token-Chain-Ring-Crankset-Bolts-Screws-7075-8-8g-Blue-/230583328579?pt=Cycling_Parts_Accessories&hash=item35afd65f43#ht_2587wt_905
It says they are used on " all double ring type applications". Are the nuts for a different kind of set up? Can I order them and just use the bolts, because thats what my set up is like?
