Hey all,
So I have an e13 drs guide that uses the bb mount - no iscg tabs on my bike (Brodie Thumper.) After every couple rides it rotates back towards the swingarm, generally far enough so the swingarm actually contacts it a bit when the bike is at full extension. The other day I looked down and the swingarm had actually bent the plastic parts of the guide off to the side making my granny gear unusable. Fortunately the drs is pretty flexible so I could bend it back.
Anyway, how do I prevent this? I'm using a holzfeller/howitzer setup and cranking that bb down as hard as I feel comfortable doing. It's a 68mm width so the drive side has the spacer against the frame, then the guide and then the bb cup. I don't think it will line up right if I have the guide directly against the frame. Also, I'm definitely not hitting rocks or anything that would cause this to rotate.
Any ideas? (Other than welding on iscg tabs...)
