If your end goal is to determine if now is too early to change the chain, the answer is NO. It is NOT too early to change.
As mentioned previously, replace the chain and if you have issues with the drivetrain with the new chain, reinstall old chain until drivetrain wears out.
A new chain on a worn sprocket will skip. A new chain on a spocket that isn't too worn will work fine.
Additional information:
A chain changed early will give you the most possible use from the cassette and chainring. Usually two or 3 chains over the live of the gears (depending on maintenance). If you wail till a chain is worn out -you stand the chance of prematurely wearing the cassette and chainring. Unsure if you knew that was the purpose of changing a chain early.
Also, given the wear of your current chain, it is near enough to end of life (in chain speak) that if you choose not to replace now, you are still probably only a couple hundred miles from replacing......and how many rides does it takes to get 200 miles.
For reference, I had about 1100 miles on the chain I replaced. Previously I replaced the whole drive train, then got 1100 before changing the chain. I wanted to change it sooner -my Park tool gauge was barely .5%, but for $30 it isn't worth wearing out a cassette. Everybody has varied results with miles on a chain.
Depending on how hard they ride (masher vs. spinner). How often is chain clean and lubed. What conditions do they drive in.
