I originally had a dmr tensioner that would work for a short time but I always had problems. The last being a hard pedal would cause a pop noise from the chain (is this skipping or binding?) The dmr had very little play for adjustment and the chain stay would get in the way if I tried a push up mode.
The roller ended up breaking so I got a sury singulator hoping the spring tensioner would give a little bit more play for adjustably. Now I have chain skip when I apply even light pressure pedaling. I read the faq on here and did have an older chain ring so I just replaced that (chain and cog are relatively new) but have the same issue.
I'm running 32x16. Is this too small? As far as chainline the lbs put on the tensioner so I believe it is good. I was thinking of just trying an eno hub. Would that help give more chain wrap as compared to a tensioner. Would I need any more than the hub and just get it laced for my current rim?
Any advise appreciated. thanks
