My guesses would be a loose chain, a chain with a nearly broken or a stiff link, chainline (viewed from the back wheel the cogs front and back should be as close inline as possible), worn chain and/or cogs, bent or missing teeth, or a failing freewheel. Best results are using SS specific cogs and chainrings with no shifting ramps or "half teeth" (I don't know the correct terminology) to aid shifting, although I have used them with success if the chainline is perfect. Singlespeeding puts a lot of stress on the drivetrain, minor flaws will rear their ugly heads sooner than geared bikes. If you're riding a converted bike with a chain tensioner like a surly singulator the spring tension may be too low.
I agree with matching your chain to your chainrings/cog. I had this same issue when I built up my One9. I put on a bmx style singlespeed chain thinking they it was stronger than the skinny 9 speed chains. Kept dropping the chain when I would attack the hills. My chaninline was good, so I switched to a 9 speed chain and haven't dropped the chain in the two years since the change. Also, I have since learned that the 9 speed chains are as strong as the bmx style chains. Hope this helps.
I had real chain-drop issues with my SS Rockhopper (sliders), but no issues with my SS Stumpjumper. The main problem on the RH was keeping chain tension.
Make sure all the parts (chain cog and chainring) have the same amount of wear. an old chain with a new chainring or vise versa has been know to cause issues.
Make sure you have the right chain size first, I have a BMX chain and it works great (they ARE meant for SS set up), and insure correct chainline. Then make sure it is as short as possible, mine slipped when I first built it, I took one link out (made the tensioner a tight fit) and it works awesome now.
How about a photo of your setup?. It does sound like a chain mismatch, but one has to go out of their way to get an 1/8" chainring or freewheel (even Surly has gone to a thinner chainring to accommodate a 9 speed chain); so I'm guessing a bent chainring tooth and a chain that's probably too tight.
After Much Tinkering That Only Made Things Worse I Went To Local Bike Shop And They Told Me:
1.chain Line Was Slightly But Not Horribly Out.
2. Shimano Freewheel Was Worn
3. Chain Had A Kink
4. Rear Wheel Skewed
They Recommended
1.new Freewheel (changing To 20t To Reduce Torque When Climbing)
2. New Chain (can't Remember The Brand But It Looks Much Sturdier)
3. Setting Up Everything Again In A Straight Line. From Scratch.
While Not A Mountain Bike Specialist They Deal With A Lot Of Fixed Speed/single Speed Conversions Due To A Big Bicycle Polo Scene Around Here.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Mountain Bike Reviews Forum
