I have an I9 Torch with boost on my SC Bronson. I have a SRAM X 01 11 speed cassette mounted on the XD driver freehub. Under QR tension I am getting chain rub and binding when I shift to my smallest ring (10 tooth) the chain is adjusted as far as I can adjust it onboard without it climbing to the next ring. It is still rubbing on the dropout/ mech hanger. I have checked and double checked my hanger and it is dead on straight at 3 o'clock to 9 o'clock and between 6 and 12. So it's not a bent hanger. I have removed, cleaned and reseated my cassette 2 times so it seems to be fully seated. I measured the face to face across my axle and it appears to be dead on 148 mm. I am at a loss..... any ideas?
Can you tell me how far the driver side end cap should protrude when measured from the outboard face of the smallest cog?
Is it possible to "center the wheel" between the hub faces?
Any help you can provide would be greatly appreciated.
