1 - 11 of 11 Posts
Old man on a bike
Sure appears the rings have real chainring bolts holding them on...running just a ramped middle ring alone is another subject :D
ps Also shorter chainring bolts...
Discussion Starter · #8 ·
One Pivot said:
you can find the better deore level crankset for the same price or just a few bucks more.
I know that but I need something with a square spindle (or whatever it's called). At the very least I just need a drive side crank arm with removable chainrings, I would prefer black. Does anyone have one they would be willing to sell.
Old man on a bike
Why not just check the specs on each crank you're thinking about? Just getting another square taper type crank may work, may not; they're somewhat bottom bracket spindle length specific for chainline (depends on manufacturer/model and the intended bottom bracket for a given chainline). Then there are different crank arm lengths; if you want to run different lengths that's up to you.
1 - 11 of 11 Posts
