1 - 3 of 3 Posts
I just replaced my rear derailer. Deore LX M570 with a Deore LX M580. LBS said it was the same derailer, just a longer cage. Also am replacing the chain. How many more links should I add to compensate for the extra cage length? Is there a website that has pictures of what the derailer should look like on a certain gear/chainring combination. Or is there some rule of thumb?
Thanks in advance.
http://www.parktool.com/repair_help/FAQindex.shtml#chain
there ya go
Thanks in advance.
Do It Yourself
A longer cage derailleur shouldn't require any additional chain length. It just adds more chain wrap capacity so you can maintian tension over a larger gear range. So if your chain was correctly sized before, the new one should be the same. It's best to just do the big ring, big cog, no derailleur, add 1" method to be sure.
1 - 3 of 3 Posts
