I've just replaced my chain, and eyeballed it to the best of my ability the correct chain length, judging from both my old chain, as well as what "looks right", after consulting Sheldon Brown's site.
So i have a few pics, and a few corresponding questions:
When on the Small/Small cog combination, i get my chain flapping around, the derailleur unable to take up all of the slack. The incoming chain to the derailleur is not in line with the tension cog, and "chatters", as it tries to skip up onto the tension cog, but can't, because of the too severe alignment difference.
So, is this "normal", as in, i shouldn't shift into this combination? I don't see this as a problem, but i do like clarification.
When on the large/large combination, I'm unsure if this is the correct length. I've matched it as close as i could with the original chain, perhaps a link longer. I would think this combination also shouldn't be used, as the misalignment is too great. And the rear sprocket keeps hopping from 1st to 2nd, due to the front chain ring pulling it down the cluster.
So, all this boils down to: Does this look right?
