1 - 11 of 11 Posts
i have a '13 gt Sensor expert 9r, and have noticed that my chain seems to flop around a lot when going off of drops, or even just bumpy terrain.
today, when zipping through a gully (maybe 30 foot vertical, 45deg slope both down and up) the chain actually came off the (rear) sprocket, made some pretty horrific noises and forced the crank around several times. This both startled me and obviously messed up my riding up the uphill side of the gully.
Is there anything I can install maybe mid-span between crank sprocket and rear derailleur that would hold it in place a little better?
XT rear derailleur, and Deore 3 sprocket crank, btw...
Should I maybe go to a 2x10 from the current 3x10 setup? I hardly ever use the big front sprocket... maybe that would allow me to shorten the chain a lil'?
I found when i first started riding this happened to me a lot.
After a few rides you should get used to landing with the back wheel first then the front, for me anyway this stopped the chain slopping around. I have not had any been chain noises since i got better at landing my jumps/hops
This should be your first step, unless you're just itching to spend money.
Also, make sure your inner limiter screw is adjusted properly to keep the chain out of the spokes, as rrdave mentioned.
Discussion Starter · #7 ·
I was in middle sprocket on front, and maybe 2nd or 3rd largest in back. when the chain came off it wedged itself between the largest rear sprocket and the clear plastic spoke protector thing.
EAT MORE GRIME
(ノಠ益ಠ)ノ彡┻━┻
that GT is a trail bike not a gravity bike
you want chain to stay put, start adding chain tensioners and guides you'd normally find on a gravity or dh bike.
if you want to low-dollar it, set up rear der limit screw to the second biggest cog, this way it reduces or eliminates the chance it can wedge up. same with front der...eliminate on ring by forcing limit screw...but usually you can shift the chain back onto the front rings
Trailhead Poseur
I was in middle sprocket on front...
That's a part of the problem. If you're going downhill or over big drops, shifting to the large front ring will take up the slack in the chain and you'll get less chain slap.
If you don't use the big ring (only the top three or so ratios in the big ring are really unique, everything else overlaps with the middle ring), you may be a candidate for a 2x conversion because you can shorten the chain which will also reduce slap - you resize the chain considering the middle ring as your big ring. It's a relatively cheap option, all you need is a bashguard to replace the big ring. You don't even need a new front shifter, you can turn your existing 3x shifter into a 2x by shifting into the middle ring and then turning the high limit screw in until it just touches the stop.
You can usually milk some more derailleur tension by messing with the B and P tension. B-tension is pretty straightforward, P is a little more work. Not sure if the newer derailleurs still have the adjustment that tightens the spring up some, but that can help also. They used to keep it kinda tucked away underneath and on the inboard side of the unit; there would be an allen head that rotated a cam around which the end of the spring was connected.
at least you still had the spoke guard on...that and the reflectors usually end up in the dumpster. It could of got expensive otherwise :yikes: & as mentioned above, a type 2 or Shadow Plus RD will eliminate all or most of this, providing it is adjusted properly
1 - 11 of 11 Posts
