Check the B-limit screw and chain length. Both could contribute to this occurring.
yes dont pedal backJust obtained a 11-50t cassette, extended cage, and oversized pulleys from Garbaruk. Went from an X01 10-42t Sram. Both 11 speed. Kept the same single 32t Sram front chainring. Now, when I backpedal from the biggest cog, my chain drops to a smaller cog. I have seen this issue in various posts, but I am checking other's experience from the standpoint of going to any cluster with a bigger low gear cog - with any brand - and not necessarily Garbaruk. And more importantly, has anyone found a tweak that reduces or eliminates the problem. This might be my first post on Mtbr, and I appreciate your patience and help.
Why the quotes around professional? They probably used the correct length. As for why your chain does this, it's a combination of several factors all combined together. Sometimes addressing one of them will bring some improvement. Sometimes that's not necessarily enough.So even with a "professional" bike shop doing the work, the result is the falling chain. So either its because of the oversized biggest cog creating a less than ideal chain line, or maybe the profile of the teeth on the Garbaruk is not optimal for pedaling backwards.
The quotation marks are to contrast the difference between the professionalism of a bike shop, who readily repair and fix these things, and myself, who is an amateur. Also, it was to emphasize that even after taking it to a "professional" bike shop, the issue exists. My sentiment therefore, and I think others would conclude as well, that this must be an inherent and intermittent issue with the 1x. This was my thought process in using the quotation marks. But you thought that the quotation marks were used as a put down. It can be, but that's not the case, here. I hope you're clear.Why the quotes around professional? They probably used the correct length. As for why your chain does this, it's a combination of several factors all combined together. Sometimes addressing one of them will bring some improvement. Sometimes that's not necessarily enough.
To be fair, you're also using a pretty mixed up drivetrain, too. Good chance that's another one of your factors, and that's not the shop's fault. You're the one that bought the parts and had them install them.
I think it's incumbent on you to make it clear because you're not using quotes around the the word the way it's most broadly used. It's most widely used to do exactly what you say you're not doing here. To insult the actual professionals (typically their knowledge and/or skill). So by putting that word in quotes, the broader (American) English-speaking world will interpret that you are saying that the bike shop employees are poor excuses for professional bike mechanics. It's not that the quotation marks around a single word can be taken to mean what I thought. It's that they're usually used that way. And honestly, this is the first time I've seen anyone attempt to use quotes in the manner you've described here.The quotation marks are to contrast the difference between the professionalism of a bike shop, who readily repair and fix these things, and myself, who is an amateur. Also, it was to emphasize that even after taking it to a "professional" bike shop, the issue exists. My sentiment therefore, and I think others would conclude as well, that this must be an inherent and intermittent issue with the 1x. This was my thought process in using the quotation marks. But you thought that the quotation marks were used as a put down. It can be, but that's not the case, here. I hope you're clear.
