1 - 8 of 8 Posts
Is there a chain guide of some sort that is compatible with a 2006 Coiler for use with 2 chainrings?
There aren't any mounts so is it possible at all?
thanks
Lets ride
Stinger
Yep, I have the '05 Coiler with the Stinger, works great. If you have the X-type BB be careful removing the crank arms, I had to replace the BB because plastic baring covers disintegrated.
thanks
solid gold plated
they work very well, quite a few coiler people use them as well as various other faux bar bikes like turners.
solid gold plated
it mounts behind the BB, so you need to remove you drive side crank, take off the BB, remove a spacer and sandwich it between the frame and the BB.
adjustment is simple enough, you change the position of the wheel according to your setup etc.
with regards to shifting, some people reported an improvement hehe
1 - 8 of 8 Posts
