1 - 11 of 11 Posts
I have an 07 GF Hifi. i switched the shifters and derails to sram x9. i broke some teeth on my cassette (11-32). i'd like to switch to an 11-34 and get a new chain. is the 11-34 compatible? i have horrible technique and shift a lot while climbing. i need something real durable for adventure racing. any help is appreciated. thanks
Banned
Learn proper technique for shifting. All it takes is a little planning ahead and backing off on the pressure on the pedals when you want to shift. Don't shift under more than 25% power and you'll save your ring gears and cassettes. Spin the gears, but under light load when you want to shift.
Old man on a bike
I'm with randyboy, doing adventure racing with poor technique just doesn't sound like a good idea. Your drivetrain is probably compatible since you're running an 11-32 now, but if you installed a short cage rear derailleur then it could be an issue; chain length might not be optimal either. What cassette were you breaking teeth off of?
Go SRAM 990 or XT for the cassette, light enough and the most durable as well. 11-34 will work fine as long as you have the long-cage RD.
And practice better shifting technique, it will save you money and pain.
Vaginatarian
yeah right, check out the reviews, Ill sell you mine , it has <100 miles and bent third ring
never crashed , no sticks, nothing, just climbing over rocks and roots on tight singletrack
if thats their most durable Ill stick with LX
I'll be switching from a 970 11-32 cassette to an 11-34 990... My bike already has a long cage X9 rd (stock component)... Will I need to add some extra links? Or switch to a longer chain?
cheers
cheers
If you can stay out of the big ring and the 34 tooth cog, you should be fine. You shouldn't be in that gear combo anyway.
if i added an extra link, would that be ideal though?
i've got a shimano chain right now, wondering if worth upgrading to the sram pg991 (regular or hollow pin) when i swap the 970 11-32 to 990 11-34?
cheers
Dont bother adding links. Don't go into big-big, end of story.
But yes, its totally worth upgrading. Love the 991 on my tass!
1 - 11 of 11 Posts
