Can't call him, im from the Philippines. i also can't send him an email, is this correct [email protected]?CharacterZero said:Call Cane Creek and ask for Malcolm.
hmm..that's a tough one. Why can't you email?sherwinr said:Can't call him, im from the Philippines. i also can't send him an email, is this correct [email protected]?
Thanks! already sent it there 2 times.. still no replyMtn. Biker123 said:hmm..that's a tough one. Why can't you email?
Send it attention Malcolm and he should respond,..her ya go.
[email protected]
Hi. This is the qmail-send program at yahoo.com.Mtn. Biker123 said:hmm..that's a tough one. Why can't you email?
[email protected]
Can i go 450? need to order it now.Mtn. Biker123 said:I saw your thread in the Turner forum.
If you want more of an XC'ish feel, I'd go with a 550# spring. If you want more DH/FR/Lift and shutlle assisted feel go with a 500#. I have been at your weight and I'm guessing your close to 190lbs with gear, right? As far as the mounting hardware, as Character Zero stated, Malcolm will get sorted. I might even check out the Enduro mounting hardware if I were you.
If the shock hasn't been serviced in over a year, I'd go ahead and send it in and definitely consider getting the valving upgrade.
I'm running a 450 and I'm closer to 175-180 w/full gear and almost the exact same leverage ratio. I feel like a 475# or 450# w/ a 2.25" stroke rating(it's a little longer and you can wind it down a bit more for a firmer feel) would be perfect. I like to run pretty deep in the travel too.sherwinr said:Can i go 450? need to order it now.![]()
I sent him an email linking this thread. I know he visits here sometimes...mostly just to laugh at Renegade thoughsherwinr said:Hi. This is the qmail-send program at yahoo.com.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<[email protected]>:
66.147.59.65 does not like recipient.
Remote host said: 550 5.1.1 User unknown
Giving up on 66.147.59.65.
--- Below this line is a copy of the message.
Return-Path: <[email protected]>
Received: (qmail 52242 invoked by uid 60001); 7 Jan 2010 13:57:08 -0000
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=yahoo.com; s=s1024; t=1262872628; bh=kOoHqre/XLcMnlgKpoEnmploM4kZ9OiZwkdxTozBQLo=; h=Message-ID:X-YMail-OSG:Received:X-Mailerate:From:Subject:To:MIME-Version:Content-Type; b=3cVgwEwclOYoiZvYQFzdvD/poqGbODbC4nXnH0T/FkQMpmZHcl2b27NE+cBdwA+lFrPeowaN9hib95bmCaUroF2nt8M3NfZz5f9HrKBLCMQ+k820+izhij3AuTOJZPJrB8cYX8taWZd59h7A1wNm5KU9wz5ZoQYFbXhmmAIXyxs=
DomainKey-Signature:a=rsa-sha1; q=dns; c=nofws;
s=s1024; d=yahoo.com;
b=Nmgx7ehRyiSwwwP9HkULgvAGGYbTOH6kGuPVOkL5RElECJCmIAc/CQKxThGIpnmMbk8Ymto678u8zDs3eZf2sAmv5s+xcKuofZwdr82MyBw0lQW7gTXmMmrOTRgk6k0ER8K49X1+M7QQNSubzDG3muTHAghFX1G2Lw8K+wdWtww=;
Message-ID: <[email protected]>
X-YMail-OSG: O4iaNzgVM1lNwNgQA2NkbitWbf8L5DDMoNKtKduy96_w48KQQ1gAtmw_NINfa2y8GTlnSZPMttYgsumXEadHrNyZhwJXjz4bFWkmlEknciflcyZonzfjIIDBR1gd_Jxfj9WAbfP6ou4XY_NwVZywAzBAEttxwaMkGETcjwbLW.K.6CRSWbNKB6xcSSYUya_MOuSi2Xp8Gjw2maH6agmGj9WNsRlutu_H3fTkTUg9VEUs30VVnpIKs6D8_lVu3xHEBebrxcncKe_Z6ruQgom8aV8LqfLAMMfZoRwuIbc8xAFizptj2pfLq3_NssQKAUtbHanI1_I3.PY1rHkHdW_ftDPSK2_VraqBpC6Npbvp8rWmuRF9Zl51Zuyq98qRvP21XkKYL8cMbU2ZgN3QjWrMhLkKIgbbUZe72p0irj5lToEnHEaocf8BH60w4vuzBvvXhj3p.2snBnTT0E89bWCtW_Uz568bjl456nIA0ruSj0KV7O11h7TTRf38Lyg5U0DYJt.Dkp3MkG641Ng18p4aMj0Bvr2QAsiyMJN1FZxetTFk_bIXnZ5ljAPQqprkMet07Ws7nLtShJvX_uafgG3CbbR_7Z7VJ_xKFAHn__w9_Rv6ICU4.qQtsHxNOWnBhIPRlOGelhCrUV6.A7Fo1QzRfweZ6N6DQP0sJP1pV.3ttSytAjvYut9bo_NRdE4PISAJ13ICbvgQTLeGYRj9SyynCbJ2Qimr5daxDtPgx2RSP3yL2gjw62qI20MydD2Cii0_8B2Mut.ltGMM0nQy.sO4DHSDOlpMNGJbtEhw4O6sznCWQW6ibYHa03TNLevbiQ--
Received: from [112.201.10.166] by web76008.mail.sg1.yahoo.com via HTTP; Thu, 07 Jan 2010 21:57:07 SGT
X-Mailer: YahooMailClassic/9.0.20 YahooMailWebService/0.8.100.260964
Date: Thu, 7 Jan 2010 21:57:07 +0800 (SGT)
Subject: Fw: CCDB
To: [email protected]
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="0-750695826-1262872627=:52237"
--0-750695826-1262872627=:52237
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
ok! last question how about the mounting hardware? is the fox and ccdb same?Mtn. Biker123 said:I'm running a 450 and I'm closer to 175-180 w/full gear and almost the exact same leverage ratio. I feel like a 475# or 450# w/ a 2.25" (it's a little longer and you can wind it down a bit more for a firmer feel) stroke rating would be perfect. I like to run pretty deep in the travel too.
If you are 190 geared you will be way undersprung. You be better getting a 500# unless you intend on dropping 15lbs
1/2" eyelets, yes. The Enduro kit or even the Fox kits will work (I think). Although I am a pretty big supporter of the sperical bearing from CC, if I were in your shoes and needed something right away I'd definitely look into the Enduro needle bearing option.sherwinr said:ok! last question how about the mounting hardware? is the fox and ccdb same?
Thanks!!!
Thanks! you helped me a lot!Mtn. Biker123 said:1/2" eyelets, yes. The Enduro kit or even the Fox kits will work (I think). Although I am a pretty big supporter of the sperical bearing from CC, if I were in your shoes and needed something right away I'd definitely look into the Enduro needle bearing option.
http://forums.mtbr.com/showthread.php?t=580885
You're welcome, ..enjoy the ride.sherwinr said:Thanks! you helped me a lot!![]()
you could still try calling using skype (the time difference is the biggest issue I suppose)sherwinr said:Can't call him, im from the Philippines. i also can't send him an email, is this correct [email protected]?
Great option. I have been using Skype for about a year.:thumbsup:crisillo said:you could still try calling using skype (the time difference is the biggest issue I suppose)
One last thing. Manitou springs will worksherwinr said:Where can i buy canecreek steel springs?
