1 - 4 of 4 Posts
My Cane creek double barrel came w/ spherical bearings mounting hardware.
I notice that there is sideways movement on the shock when mounted on the frame due to the nature of the spherical bearings. Is it safe to use these bearings? Won't it cause any problems on the links of the frame? Or should i replace it w/ DU bushings? My bike is a 2010 Titus El guapo.
Don't fully understand what you mean by sideways movement but my CCDB w/ spherical's can twist in position. The frame & linkage should be self supportive, its not the shock's job, otherwise you would stress the shock's internals.
1 - 4 of 4 Posts
