OK, it seems like a number of DW spot owners are running CCDB's .
I've just got mine, but I will need to bump up to the next spring rate (600lbs) to get the right sag.
I read this on the Pivot Forum...
_dw said:
The Firebird is going to work awesome with a coil shock, and the DB is a great choice. Put it on, go light on the low speed compression, with a little high speed compression and light low speed rebound, high speed rebound to taste (you don't want to be getting bucked from bottom out). It might take you a little bit to dial it in, but I guarantee that the potential is there to be an awesome ride.
Dave
I think he was suggesting these starting points would work well for DW spot.
I'm at 1 turn from open HSC, 5 clicks from open LSC, HSR & LSR at factory setting.
I hope to have the heavier spring in a weeks time ,so some more tuning/experimenting will have to done.
So what are you running?
If you can list your ride weight , spring weight along with the settings you have ended up with?
Can we keep the thread on track, thanks in advance.:thumbsup:
