1 - 5 of 5 Posts
I just picked up a used CCDB for my 2010 Del. It came with the spherical bearings already installed. I took out the one on the bottom and replaced it with a DU bushing and the appropriate hardware for the 40mm gap. The top one is 22mm and so I thought I would leave it in there and use it as is. Is there any reason why I cant be running the spherical on the body end of the shock? I know that Cane Creek and some bike manufacturers recommend not using them depending on the shock/frame combo.
Anyone have any thoughts?
Cheers
Buzz
Perpetual Hack
Ran my CCDB on the DT with the spherical bushings.
When I went to the Delirium, Chad at CC recomended changing the spericals for the Fox std. ( Had the updated popet valves and a rebuild done at the same time )
...although he still thinks ( as do I ) that the spherical is a superior system, due to less binding etc...
I can see changing out the bottom due to the length and possible torquing, but the top mount should be fine without changing to the "inferior" bushing style.
JMO, YMMV
michael
The spherical bearings put more load on the fasteners and can cause them to bend or break at a lower load than a bushing which spreads the load. Spherical bearing are not needed in a Delirium (or any Knolly) as they are generally used to compensate for suspension designs that cause side load on the shock. The 4 by Four linkage isolates side load so the shock can focus on what it is designed to do.
Discussion Starter · #4 ·
As a follow up to this question, is there a reason why most Deliriums have the reservoir (if the shock has one) at the rear and pointing down? Any reason why it cant be at the front pointing up? I have fitted my CCDB in the front/up position and there seem to be no clearance issues, is there some reason why I shouldnt be setting it up this way?
Buzz
Clearance is good either way.
However, when fitted rear pointing down, the bike can be clamped easily into a repair stand anywhere on the top tube. Also, for carrying the bike up unrideable terrain, it is easier to get a good grip on the top tube.
1 - 5 of 5 Posts
