Cassette carrier dimensions
819 Views 13 Replies 6 Participants Last post by  real_psyence
Would anyone be kind enough to enlighten me with dimensions of the cassette carrier (shimano), the width and the od of the splines and between the splines? Thanks!
_MK
1 - 14 of 14 Posts
Huh?
Way Too much work.
I think all you need to know is the following two facts:
Shimano = slop & a prematurely worn out freehub body.
SRAM = perfection & a long lasting freehub body.
G
i disagree with the previous post in that a properly spaced and tightened cassete is not going to cause any damage.
HOWEVER...
the new SRAM cassette with the red spider is pretty trick looking. :)
Disagree all you want...then perform the following test:
Take a new Shimano compatible cassette hub off the shelf.
Grab a brand new Shimano XT or XTR cassette (just the carrier part with the cogs attached).Slide it down over the hubs cassette body. Now grip it with your hand & move it in a parallel orbital rotation. Notice the play? Ridiculous huh?
Now do the same test with an SRAM cassette. Slide it down over that Shimano comapatible cassette body & try to give it the same parallel orbital rotation. Where did the play go? :rolleyes:
Choose & spend your hard earned dollars wisely.
I don't care to know your cassette preferences. I would like to learn the dimensions of the hub so that I can machine myself some spacers for a single speed conversion.
_MK
So you want the measurements of a Shimano freehub body, or a Shimano cassette carrier?
The piece of the hub onto which you slide the cassette, King calls it drive shell, but in their terms it includes the engagement teeth and a bearing. I assumed it is called a cassette carrier.
_MK
_MK
Here's the ID of a spacer from a King SS hub, 34.75mm, or 1.368"
Monte
Monte
Thanks.
_MK
Bringing this thread back from the dead because it was the only one I found to deal with this issue. I found some tubing from which I could cut spacers, so that's all gravy, BUT...the OP's question is more detailed, and I too would like the answer.
Where can I find engineering drawings of a shimano-compatible freehub body? If for example, I wanted to have cogs made, or spacers that fit the splines.
perfection?
my last sram990 had a burr on the third cog so it wouldnt even go on the freehub, after filing it finally went on , then 4 rides later the 2 largest cogs were bent so badly that the chain wouldnt stay on them. they warrantied it but I wouldnt say perfection
no play on my I9 hubs, although the Sram aluminum spider is easier on the freehub body than a steel carrier
why not go to a lbs and pick up a old one ?
mostly because I assume there's a reference diagram, "standard" as this is...
and secondly, because I don't want to be plagued by cumulative error, of the original machining, of damages/distortions from use, my measurements, and then the machining I have done based on said measurements.
It would be better to have an original spec, ideally from Shimano (who don't reply to e-mails)
1 - 14 of 14 Posts
