1 - 10 of 10 Posts
hey all,
great forum, going on my first real bikepack adventure next week and have a question about spare tubes + sealant. i did a search and didnt find anything, i assume this has been dealt with before??
background is i have a pugsley with homemade tubeless brew in the tubes and it has been great, no flats since i put sealant in. knowing me and how overly prepared i like to be, i wanna bring some spare tubes with me on my trip, but i dont trust just plain old tubes anymore, i want/need sealant.(or so i think)
so do i put sealant in them at home and carry the tubes, maybe not get a flat, and continue carrying them? will the sealant dry up and harden up eventually leaving me with bricklike wasted tubes/sealant in a couple months?
or do i carry 2 normal tubes and a bottle of sealant, hope it doesnt leak, and if i flat out there inject it on the road?
injecting it at home would be alot easier but not too bad out on the trail.(prestas)
thanks all
EDIT: i have tubeless brew in the tubes, not a tubeless setup.
no trees are safe
Many tubeless sealants don't work with tubes. I don't know why, but it happens. Perhaps the way that tubes stretch? Sealant for tubes has to have higher viscosity, or else it will just spray all of its surroundings with latex or whatever you use. If you want to be extra sure get some slume tubes and be sure you don't exceed the maximum tyre volume for the tube.
Picture Unrelated
I have never found sealant to function in tubes. I too attribute it to the way that tubes stretch when they're punctured, but I can't be sure. So I would not put sealant in the tubes at all, home or not. It should be a rare day that you do enough damage to need to put a tube in but you can always take it out when you get back home or the car or wherever you are based out of.
I carry a tube or two (or more if I'm going to be out for a long ride with a lot of danger) plus a patch kit. That way I can patch tubes or tires if need be and always make it out of the trail.
I personally wouldnt want to deal with spares tubes filled with sealant. I think you'd be better off keeping 1 or 2 normal tubes in the pack. I've always had good luck with tires setup tubeless and have never had a flat. I've burped a little air here and there, but nothing a co2 cartridge or hand pump won't fix. I always carry one extra tube, 2 co2 cartridges, and a patch kit. No matter if it's a quick trip around town, or an all day epic. Knock on wood...been running tubeless for years with great luck and the only time I've pulled out the spare tube was to help another rider. Your worst enemy is a sidewall tear when running tubeless.
No need to put sealant in your tubes. If you puncture your tubeless you can repair it with a patch. If you put a tube in then it'll function just fine.
Sealant typically doesn't work in inner tubes because of the chalk inside of the tubes that prevent the tube from sticking to itself when it's not inflated. The sealant won't stick to the butyl and repair the tube.
You can buy inner tubes with sealant already installed and they work great which debunks the 'tube stretching' theories posted here.
Hutchinson makes some great ones called Protect'Air.
Although finding tubes with sealant in them in Pugsly size will be tough!
I hope this helps.
Picture Unrelated
You can buy inner tubes with sealant already installed and they work great which debunks the 'tube stretching' theories posted here. .
They absolutely do not work "great". Some work to a minor degree with small punctures, none will cope with a puncture as well as a tubeless system will.
It can also be very difficult to seat tires tubelessly on trail which is another reason most people recommend carrying tubes, sealant filled or not. CO2 is not recommended with most sealants I am aware of.
no trees are safe
You could try out Michelin Protek Max tubes. They have mixed reviews but most people say they work good.
I wouldn't mess with carrying a tube of sealer. Instead, I would carry a Slim tube (tubes with sealant already installed) and a patch kit. Tubes with sealant already installed works better than installing sealant in a typical tube. It's not a cure-all solution though an really only works with small leaks. I would also install some Teflon tape or other puncher resistant barrier between the tire and tube. After that, make sure you have the tools and patches to fix flats.
I think you'll have better luck outside running the tubes+ sealant combo...
My order:
tubeless setup with spare tubes/ patch kits (you'll probably never need them, I haven't in 18 months)
tubed setup with a durable tire, heavy durable tube, and maybe the liner if you like that kind of thing, I've never had luck with them. Your local shop probably has some super HD tubes if you ask though, that will probably help!
1 - 10 of 10 Posts
