Ti Motolite?
Sounds like the Ti Motolite frame for $2195 from Jensen would be perfect for your needs. 5" for rougher courses, convertable to 4" for smoother courses, and the frame is under 6 lbs. Oh and a lifetime warranty on the main frame.
I had mine all picked out until one of the more informed Titus folk posted that in my size (small) they used only a 1.5" stroke shock for a 3.33:1 leverage ratio. At 5' 11" you would use at least a medium which has a 2" stroke for a more common 2.6 or so ratio like the venerable 5 Spot.
The only problem I had with the FTM was a for me too steep head angle, but as an xc guy you might like that. Good luck.
