Carbon wheel repair
4299 Views 12 Replies 6 Participants Last post by  plummet
10
So..... I'm smashing (literally) down my favorite descent. I don't get to ride it often because it's a dry ride only track... ie it's too steep and crazy to be ridden in the wet. I'm in the zone and fully flowing at pace.
I crank down the last bit of super tech and run a bit wide compared to my normal line. I'm on form so a just let it run and smash through the roots and hear a low crack..... I check the rear wheel and ah **** the carbon rin rim has been crushed in a couple of spots. Damn it. The rims are line 3 months old. I check the rear pressure. Way too low for the speed and size of the roots I'm hitting.
Righto. I need to keep these wheels going while I wait for a replacement rim. Time to bust out a carbon repair.
And here it is.
Offending root section that damaged the rim.
Bicycle Bicycles--Equipment and supplies Tire Wheel Crankset
Rim damage
Tire Wheel Bicycle wheel Automotive tire Bicycle tire
Sanding back to flush
Automotive tire Sleeve Denim Asphalt Thigh
Bits of carbon ready for layup.
Wheel Tire Tread Automotive tire Automotive design
Layed up and clamped with plastic cover foam strips with cable ties.
Wheel Bicycle Bicycle wheel rim Tire Bicycle wheel
12 hours larer. ut of the foam press and ready for blending
Tire Automotive tire Plant Terrestrial plant Twig
Internal repair view
Tire Wheel Bicycle wheel Bicycle tire Automotive tire
Blended, polished, tyre installed and ready to ride.
Bicycle Tire Bicycle wheel Wheel Bicycle wheel rim
Bicycle Tire Wheel Land vehicle Crankset
Wheel Bicycle Bicycles--Equipment and supplies Tire Plant
There was no problem seating the bead and the tire held pressure immediately. I went for a quick ride and smashed down some chunk including a pretty harsh square-edged concrete flight of stairs. Repairs have held. The wheel doesnt feel any different to the pre-crush wheel.
I'll be honest I'm pretty stoked how the repair came out. I was looking at the alternative of shelving the rear wheel until the replacement turned up in a month or so. Now I can schralp and shred with reckless abandon.
Now for the long-term testing.
  • Like
Reactions: 5
1 - 13 of 13 Posts
1000m vert descending this morning with some damn harsh high speed root sections.
Rim repair still look good.
Stoked.
  • Like
Reactions: 2
Did you loosen the spokes at that area for the repair? What layup glue?
No I did not loosen spokes. The rim was true so I left sleeping dogs lie and did the repair under tension.
West system epoxy resin.
Nice! Has the balance of the wheel been affected?
Not that I can tell. Did 70kph down a hill on the road after my 1000m vert descending this morning with no I'll affects.
  • Like
Reactions: 1
4
Done another 2100m of vert descending of some pretty gnarly root and pointy embedded rock tracks. The repairs are still holding with no sign of failure.
Tire Wheel Bicycle tire Plant Automotive tire
Wheel Tire Bicycle wheel Plant Bicycle wheel rim
Bicycle Tire Wheel Bicycle wheel Water
Tire Wheel Land vehicle Vehicle Plant
  • Like
Reactions: 1
Carbon is so eco friendly. No fatigue limit and able to be home repaired, truly the responsible man's choice.
  • Haha
Reactions: 1
Well done!
Sent from my SM-G715A using Tapatalk
We are of course carbon based forms..... we are embracing the inner self when we choose carbon.
  • Like
Reactions: 1
Had a minor crack in a wheel so that it wouldn’t hold air/sealant. Warmed it a bit with a hair dryer and flowed some Crazy Glue into the crack. A bit of sanding and good to go!
The bigger question is why is there a crack there? you might want to think about a strip or 2 of uni-directional across the crack to provide extra strength and reduce the chance of crack propagation. An old aircraft engineering trick is to drill a small hole at the end of the crack. This dissipates the stress riser and reduces the chance of further cracking. (obviously fill any holes drilled in carbon with epoxy.
  • Like
Reactions: 1
1 - 13 of 13 Posts
