CF composite construction strength is related to how hot the curing temperature was. The warmer the curing temperature, generally the better the strength. For a long while, the FAA required all composite aircraft be painted white, to reject heat, if they were operated beyond their curing temp, there could be a loss of strength. This was more related to operation though, not storing. With better epoxy/resin formulas, this is not nearly the issue that it used to be and composite aircraft are being painted darker colors. If you ever have to repair your CF frame though, your garage sounds like an excellent place to cure it! I wouldn't worry about this, as the other people said, you'll have a harder time with tires and especially the tubeless sealant. It will dry fast. You can mix some propylene glycol and water and inject that every couple weeks to help keep the latex liquid.
