What rigid carbon forks exist on the market today that can be used on a 29er that originally came with a 100mm travel fork without throwing the geometry off? Do the White Bros. and Niner forks fit the bill? Any other more budget friendly options?
driver bob said:The new RXL is suspension corrected but I don't know if thats for 80mm or 100mm
http://trekstoremadison.com/product...e-fork-29-inch-1-1-8-inch-steerer-60589-1.htm
I will see if I can help a little.zuuds said:What rigid carbon forks exist on the market today that can be used on a 29er that originally came with a 100mm travel fork without throwing the geometry off? Do the White Bros. and Niner forks fit the bill? Any other more budget friendly options?
Yep, and 490mm is considered correct to replace a 100mm susp fork. I don't remember seeing any 490mm carbon forks thoughLoki said:I will see if I can help a little.
The white bothers that I have is has an axle to crown of 465mm, it is suspension adjusted for a 80 mm fork. The niner fork is 470, so your a little closer... They both have the same rake of 45mm.
Hope that helps..
Not compatible from what I remember. I didn't know they made a 7mm too. More options is good; I could only remember the High Five crown raceTiRyder said:King makes a 7mm tall crown race to get you that smidge closer.
I dont know if the King race would work with the CC plus 5, but that would net 12mm. Add that to the 470 Niner Fork and you are pretty close at total 482, especially if you used to run the fork with lowere pressure/more sag.
Yeah, I run a seven on my moots with Fox fork. The 5 would have cleared it barely, and I went with the 7 just incase there was any weird pressure going on in a wreck, didnt want the Fox knob to score or otherwise muck up the DTboomn said:Not compatible from what I remember. I didn't know they made a 7mm too. More options is good; I could only remember the High Five crown race
I think you are thinking of their steel fork, which used to be 490mm only but now they offer both. The carbon fork is brand new and 470mm only; unless there are some pre-production prototypes that were 490mmJwiffle said:Niner used to offer a 490mm A-C carbon fork; they now produce their forks with 470mm. Maybe you can find a 490mm one floating around.
But when fork length is the only thing that changes it could be quite noticeable in handling and could drop the BB too low for rock clearance on certain bikes and trails. Switching out the 470mm rigid that my bike was designed for with my 100mm susp fork raises the BB by ~1/2"; I wouldn't want to do the opposite to any bike that has a low BB height to begin with. Also, the head angle would steepen by ~1 degree or maybe even a hair more, which might not be desirable on some 29ers that already have 72deg HA's or even steeperYogii said:20 mm is not a heck of a lot. Tires at 18psi or 40 psi????
2008 and earlier is 510mm without sagzuuds said:Does anyone know what the axle to crown measurement is on a 100mm travel Rockshox Reba with about 20-25% sag dialed in? I'd measure it myself, but Idon't have the bike yet![]()
Aha! Well then 506mm - 25mm sag = 481mm, so the 470mm Niner fork is only a 11mm difference = good to go? If that messes up the geometry/handling, adding the Cane Creek +5mm headset would cut that to 6mm.boomn said:2008 and earlier is 510mm without sag
starting in 2009 it is 506mm without sag
