On one hand i'm surprised this isn't more of a thing. On the other hand, i guess the typical XC demographic isn't riding flats so the demand just isn't there.
Despite that, there's a few options if you dig deeper. After scouring the AliSuckspress, i found a couple to experiment with on my new WW build.
The first item was a set of Zeray ZP-D213 weighing in at 238g. These aren't carbon in the sense we're used to, rather a composite of nylon reinforced with carbon fibers as it would seem Lighter/stronger/cheaper than plain PA6, but not as light as pure CF. But being nylon, the strength should be a known quantity. An all around average flat pedal in the areas of features, pins, size, etc.
https://www.aliexpress.com/item/32835182770.html
The second is a complete CF pedal with a Titanium axle. Much lighter at 162g but the size is comical. I personally run a larger flat pedal and these seem like they'll be unusable to me. Still, the weight is admirable. another downside is that it seems rather exposed with respect to the end of the axle. But the strength is unknown at this point. Perhaps the smaller size is because of whatever limits the CF construction may impose (assuming any structural analysis went into these at all).
https://www.aliexpress.com/item/32964992300.html
