Thinking of getting the following for my new 575:
Easton EC70 MonkeyLite CNT XC Riser - MTB Carbon Black 660mm-1" Lo Rise-31.8
Apparently these bars are reinforced inthe brake and shifter clamp positions so..
was wondering if it's ok to use a set of Yeti Odi lockon grips or should i use push ons?
Big fan of carbon seatposts so much so i'll never use Al seatposts ever again but not too sure there are any benifits for bars other than weight?
Also fancying this stem or would people reccomend the non X4 type?:
Thomson Elite X4 MTB Stem 90mm 10 Deg 1.1/8" 31.8 Clamp BLACK
Any thoughts much appreciated.
Just test rode it tonight and everything works first time
- only one click on the rear derail barrel adjuster and it was perfect. Only issue is the Formula The One brakes - I think out the box there is more air that Dot oil in em - low power with no leaver resistance and pumpin the leaver rapidly ramps up the lever resistance quickly = airlocked.
