I just got an endurace for commuting, and im keen on attaching my thule chariot sport 2 trailer.
Having no experience with flimsy roadbikes, will it handle the extra 30kg ish on the side of the rear axle without distortion when braking or pulling?
Thule doesn't make rear axles that work 100%. The closest is the x12 syntace m12x1 and 160mm long axle, but the head is conical, whereas the original is flat. The thule head has a small flat surface at the inside. I'm thinking of either make a custom shim in the lathe with a counter countersunk hole, or just use a flat steel shim. ( I'm a lazy guy) Any input?
Sent from my SM-G950F using Tapatalk
