1 - 10 of 10 Posts
Nater said:
I don't think you'll have any trouble. Pick up one of these and you should be ready to go...
QBP part #BR7151
Fits an M8 seatpost binder bolt.
Except that the binder bolt isn't in the rear on Inbreds. The seat tube "slot" faces forward.
Get the QBP part and just rotate the seat clamp so the bolt is in the rear. The binder bolt does not have to face the same direction as the slot.:thumbsup:
Discussion Starter · #7 ·
Sounds good. Anyone tried cantis on the back of an Inbred? - will be keeping disk on the front, just fancy the mud clearance (and look) of the canti on the back - or am I being unnecessarily 'retro'?
So make another small slot at the back to have the hanger nestle in (as otherwise it will hit the seat tube, it actually needs a slot to sit in. Cutting a small slot will not affect the frame.
They also make hangers that mount on the outsides of the binder bolt. They are Y shaped. Then you don't need to cut the slot.
1 - 10 of 10 Posts
