Good question
pathfinder said:
Howdy,
Does anyone have any worries about buying an '03 KHS? I think it looks like a beautiful bike, as does the 904r, but they're almost 2 years old. I also think the "Hollowpoints" seem to be a great deal, especially when the spec is considered, but they just look heavy compared to the KHS and Giant models. Anybody know if the Hollowpoints are chunky say 30+ pounds? Light, less than 30 pounds?
I think KHS makes fine bikes. In particular, the 904. As much as I hate to "label" (ie, trailbike, freeride, etc.) bikes, I think it helps here.
The 904 is a race-ready true XC full suspension whereas the Hollowpoint is more of a trailbike. Certainly the high-end Hollowpoint has lighter parts and certainly could be raced but in general, are make more for all around riding. Not sure which Giant model you are referring to but the NRS series would also be in the true XC category with the 904.
I am not sure but my guess is that the Hollowpoint Sport (the one for $1099) is probably at about 31 pounds or so but this is a guess. However, if I recall correctly, the tires are much heavier than they need to be so you could probably very easily get it closer to the 30 lb mark.
If you plan to ride relatively non-technical riding with lots of fire-road climbing then a more XC oriented bike (as opposed to a trailbike) will be the better choice. If you plan on doing some drops and more technical riding then a trailbike (or all mountain or whatever people call it nowadays) will be a better choice. Only after you decide on what type of riding you will be doing should you then consider weight etc.. In addition to the generall difference in weight between these 2 types of bikes, the geometry is different so they will feel different as well (XC steeper/shorter wheelbase for climbing, trailbike slacker for more stability downhill and more upright riding position and of course much more plush).
If my memory serves me correctly, the 904r could be had at $1799 somewhere (I think pricepoint.com) which is in incredible deal if they are truly offering it as specd by KHS. Not sure if it is still available.
So I guess the bottom line is that more important than weight I would focus on the type of riding you will be doing (and more importanly planning on doing) and then narrow down the choices. My personal feeling is that most people go with the trailbike/all-mountain category which is typically 5" front and rear and dont need to (including myself....but the marketing got me!!). In my defense though, I do prefer the more upright riding position than you would get from a true XC bike but 5" travel is more than most people need most of the time. But the handicap for bad riding gained does make you feel safer.
Hopefully some of this answers your question.
Cheers
