You've probably solved this problem since frigging July when you posted it but...
I've had problems w/ various King hubs over the years. My own and customers. If you run a highish spoke tension it can actually stretch the King hub shell making it always feel loose. No matter how you perform a bearing adjust it'll always feel loose.
Out of frustration I spoke w/ King (this was in about... oh... I'd say 2002 or so) and they told me of the stretch problem. They have bearings that are just barely larger. By like a 1000 of an inch or so.
I sent the hub back, they pressed a larger bearing in and everything was all set.
Now as a fix for this problem- and other King issues- I just use DT 240s.
