Ok, judge me if you want, but I'm turning an old Jekyll 3000 into a 69er....because apparently I huffed a little too much paint in my youth?
So, I found an Ocho and I've got the KP205 reducer kit. First question: the bevels on the bearings face away from the headline, correct?
Also, I've got the fork, reducer kit, brake mounts. My current brakes (older IS mount XT) will either need replacement or an adapter. Is there a reason I can't just replace the caliper with another Shimano caliper that's post mount? Or should I just get a matched lever/caliper set?
I know I'll need a new stem/cap and until I hunt down a lefty60 29" wheel, I've got the rotor spacer to run my 26" wheel (and maybe a lefty 50 29" wheel of I don't find a lefty 60 wheel)
Is there anything I'm forgetting?
