Hi!
I am currently riding a Cannondale gemini size small and I have the occasion to buy a new Santa Cruz Bullit frame (2007) for a good cheap price. Should I make the move? What do you think will be the main difference/different feelings between the two frame? My current set up is with a Sherman Breakout Plus in the front, double crown fork.
Santa Cruz Bullit 2007
http://www.vttfreeride.com/index/news-357-presentation-du-bullit-2007.html
Santa Crus Bullit frame 2007 Size Small Geometry
TT 21.5
ST 15
ST (angle) 70.5 deg
HT 4.1
HT (angle) 67.5 deg
Wheel Base 41.9
BB (height) 14.3
CS (length) 17
Gemini Geometry Chart size Small 2003 Geometry
Seat Tube Angle (degrees) 71
Head Tube Angle (degrees) 67
Horizontal Top Tube Length - Horizontal (cm) 57.5
Horizontal Top Tube Length - Actual (cm) 53.1
Seat Tube Length to Top (cm) 40.5
Chainstay Length (cm) 43.2
Bottom Bracket Height (cm) 37
Wheelbase (cm) 109.2
Trail (cm) I 9.6
Standover Height (cm) 72.4
Bottom Bracket Drop (cm) 2
Front-Center Distance (cm) 66.4
Thank you for letting me know if you think i will notice a difference in the bike handling due to the geometry!
TT 21.5
ST 15
ST (angle) 70.5 deg
HT 4.1
HT (angle) 67.5 deg
Wheel Base 41.9
BB (height) 14.3
CS (length) 17
Trail (cm) I 9.6
