1 - 20 of 20 Posts
The White Jeff W
Discussion Starter #1 (Edited)
Canfield Yelli Screamy - Happy Birthday!
I revived this thread for my Yellis 3rd birthday. 3 bikes have come & gone since I built this and it's still the one I reach for first. Ive changed a lot of things since I first built it but still love the bloody thing.
Finished my Yelli this morning. :thumbsup:
XL frame
Marzocchi 44 Micro TI @ 140mm
Stans Flow Wheels/Hope Pro II hubs
Specialized Purgatory 2.4 tires
Formula Oro brakes
Truvative Stylo single speed cranks
Shimano 12/36 cassette
the WALKING DEAD
Sweet sled. Please post back with your riding impressions. How do you like the head angle, bb height, chainstay length, etc. How does it compare to your last bike? Also, what was your decision making process when deciding on this frame? How did it look coming out of the box, were all the surfaces machined? Thanks.
The White Jeff W
Discussion Starter #4
I've only had it for a spin around the neighborhood so far. Right off I can tell it's too tall with the fork at 140mm. The handlebar sits about an inch taller than my Yeti 575 with a Fox 140mm fork. The HA is 69* with a 100mm fork so as you can imagine it's pretty slack at 140. I'll give it a go at 120mm but I suspect 100mm is gonna be money for where I ride. Other than just feeling tall it seemed to handle pretty well and felt well balanced.
I chose this frame mainly for the slack HA and short chainstay length. One of the things keeping me away from 29ers was the fear of it being big & clunky so a tight frame like this seemed like a good starting point, + the price was right
Pedaling is very responsive. The ride is nice. I'm not sure if it's the frame, the 29" wheel or the big fat tires but it was noticeably smoother riding than my Chumba HX1. Tons of tire clearance in back. The fit & finish is very nice. It went together with no surprises or drama.
Just waiting for the snow to melt so I can get it out for a proper trail ride. I'll update after I get a few rides in.
The White Jeff W
Discussion Starter #5
Chromagftw said:
Very nice Jeff. Looks real comfy with the slack seat tube. :)
Do you have an overall weight for it?
Just under 29 lbs with 800 gram tires + tubes + a little snow on the tires. I'll set it up tubeless when I get a chance.
think
Flip the stem and run it at 140. That stems got a whole bunch of rise in it, and I bet the bars have some too. You could bring the bars down a whole bunch easily.
The White Jeff W
Discussion Starter #7
I thought about that but its still gonna be really slack up front and high at the BB. I need to open up the fork to do the anti stiction mod anyways. I'll probably give that a try first tho. Did wonders for the handling on my 575
I think this is a good idea. :)
You've got nothing to lose by trying it. Get the handlebar height where you like it before f'ing with the fork.
Super fun bike, enjoy it!
Missouri sucks...
Got mine done too:) It's a Medium. No ride impressions yet since there's been a crap ton of snow on the ground for a couple weeks:(
Parts list:
-2010 Medium Silver Yelli Screamy
-2010 Fox F29 RL 120mm tapered steerer 15mm thu axle
-Shimano SLX crankset and bottom bracket. Using Truvativ NOIR carbon bashguard and ti 32t sprocket
-Blackspire Sub4 pedals
-SRAM XO super short cage
-SRAM X9 trigger shifter
-EDGE flat carbon bar
-KCNC 70mm +5/-5 stem(soon to be replaced with a Syntace Superforce 75mm +6/-6 stem)
-Some crap seatpost I had laying around(ControlTech post on the way)
-Specialized Phenom Expert 130mm saddle
-ESI Chunky grips
-Formula RX brakes with sintered pads
-Hope SAW 160mm rotors with ti bolts(front is going to be 180mm when adapter shows up)
-Salsa QR seatpost clamp
-Connex 911S chain
-Bontrager FR3 2.3 tires
-Gorilla Tape tubless conversion with Stans valves
-Salsa Semi 36h 30mm rims
-DT Swiss Competition spokes
-DT Swiss alloy nips
-Hope Pro2 front hub
-Hope Pro2 singlespeed rear hub
-Shimano XT 34t cassette with custom machine work by Waltworks. Using top 6 gears on the carrier and one 13t loose cog.
-modified MRP 1X bottom bracket mount chainguide. I wanted a bashguard so I'm only using the inside piece which I ground down extensively with a bench grinder. Works great! I've had the guide for a few years so I didn't destroy a brand new piece;)
The bike weighs 26.6lbs as it sits. Should drop to around 26.4 when the new seatpost, stem and brake parts show up. Not really concerned with weight on this build but everyone always asks;)
Nice looking whip!! how are those purg tires holding up for you?
The White Jeff W
Discussion Starter #14
I liked them while I used them. Relatively light for a big knobby tire and tons of grip. At some point I changed over to lighter less aggressive tires for the dry summer conditions then put them back on in the winter.
The White Jeff W
Discussion Starter #15
You're making me nervous about the weight of my upcoming Nimble 9 build up! I don't have too much money to throw at it and if these builds are pushing high 20s I'm unsure where I'll end up.
Probably high 20's! lol
I hover around 200 lbs so I tend to over build my stuff. Heavy, yes, but takes a beating.
I just finished my Yelli and it ended up at 25 lbs 13 oz. Here's the build:
Revelation Dual Air 140mm
SRAM XX1 cranks
SRAM PG 1070 cassette
SRAM X9 shifter
SRAM XO 10 spd RD
Canfield Bros Crampon Mag pedals
Easton Haven carbon bars
Lizard Skins Peaty grips
Cane Creek 110 headset
Crank Bros Cobalt 3 stem
Crank Bros Cobalt 3 seatpost
Crank Bros Cobalt 11 saddle
Shimano XT brakes
SunRingle Charger Pro wheelset
Kenda Nevegal tubeless
Could have gone lighter on the tires, used foam grips instead of lock-on rubber, and gone lighter on the seatpost and stem. But overall a pretty light setup and it climbs like a mountain goat. I have been having issues with clearance on the XX1 cranks, which I am still trying to troubleshoot, but I have been super happy with the bike so far.
My friend just got one of these and its really nice. He built it up as a SS and its pretty light for what it is!
1 - 20 of 20 Posts
