I wanted to share my most recent addition/change to my DH bike. I had been borrowing an e13 direct mount stem from a buddy but he recently got another boxxer and I thought it was time to return it. I have a .5 in rise bar but have always wanted a lower setup and so looked at stem choices for this. I never necessarily felt the front end was high with the e13, but I did always notice it was taller than I was used to with my trail and jump bike. You accept that as ususal, forget about it 30 seconds into the run and life goes on. But I knew there were options and instead of getting a flat bar to replace my perfectly good current one, I used the new stem as an opportunity to go lower.
I ended up getting the Canfield offering. I have a couple of their frames and although they are not the only ones offering drop stems, brand loyalty came into play for sure. First ride out was very satisfying. Instantly felt natural, cornering was amazingly easier. We have a step down to tight'ish right hand burm into a step up that sets up a 20 foot gap and I was amazed how I was overclearing the step up with just a stem change. Hitting that burm harder and with more confidence and then having to pedal more into the gap as I was overshooting the step up. They advertise and inch drop and it is noticeable both visually and huge difference on the trail. Here are the pics so you can see the difference for yourself before and after. If you are thinking about getting that front end down, this is a fantastic option and I am a very happy rider.
