1 - 8 of 8 Posts
· Registered
Discussion Starter · #4 ·
Took apart the kitsuma to change the stroke from 57.5 mm to 65 mm.
I used the same shimano bottom bracket tool to take the air spring body off the bottom eyelet that the double barrel uses. Then I put the 9.5mm shaft in my vice clamps, warmed up the eyelet body with a heat gun and removed the eyelet body, then the white plastic spacer.
This made the 57.5 mm shock into a 65 mm shock. If you want to make it a 60 mm stroke you will need a 2.5 mm spacer.
One interesting addition to the shock shaft was a 4 mm hex on the end of the shaft to be able to remove and reinstall the eyelet body onto the shaft without a 9.5 mm shaft clamp.
The shaft sealhead can be removed with a park pr2 cassette tool.
· Registered
Discussion Starter · #6 ·
About to do the exact same stroke change to my Kitsuma Air. Can you point me in the right direction of the tool you used to remove the sealhead? I can't find the Cane Creek tool (BCD0344) anywhere. Something like this?
BB Tool HT II - Spanner Fitting
This is the one I used.
If you are doing a kitsuma you don't need to clamp the shaft to get the eyelet off. The eyelet has provisions for a hex key on the end and you can unbolt the eyelet after heating it uo and releasing the loctite.
· Registered
Really appreciate the response on this! The tool I am referencing is on step 2 of the guide below. I guess I don't follow how a cassette tool fits over the damper shaft and onto the splines of the sealhead.
https://canecreek.com/dbkitsuma-air-stroke-change/
The rest of the process seem fairly straight forward
thanks again!
· Registered
You don't need to remove the seal-head. You need to remove the eyelet from the end of the shaft. Shaft clamps if you haven't got the through hole and eyelet bushing out.
Pretty sure it's not a cassette tool for the shaft, it's the bigger ISIS BB tool like the Fox X2.
1 - 8 of 8 Posts
