WOW, I had a chance to put my hands on a set of these a few days ago, I WANT!! Look more like Art Work than a crankset, and LIGHT! The box they were in was heavier than the crankset, but damn that price!
Twice as stiff as Race Face Next R, and lighter too. Not too shabby. Check out this video: https://www.youtube.com/watch?v=yU0LNcYF734Ti isn't very stiff. Seems like a strange material to make cranks out of. But they are sexy.
Ha, true. Add a few grams.You forgot the mounting screws for the Sram chainring.![]()
Man I like the product. That video though...Twice as stiff as Race Face Next R, and lighter too. Not too shabby. Check out this video: https://www.youtube.com/watch?v=yU0LNcYF734
Except for in a carbon fiber crank, where flex indeed means lost energy. Buy mainly for higher frequencies than pedal frequency.Man I like the product. That video though...
Clearly engineers or physicists were not involved in the script. A flexible crank doesn't lose energy, it might suck to ride a really flexy crank but since a flexible crank is a spring the energy that goes into flex comes back out. The only loss would be energy lost as heat.
They should sell the thing on its (many) merits, not confused blather about the performance benefits of extreme stiffness.
You're technically right that there is some energy lost as heat, and an aluminum 30mm spindle is more flexible aluminum 30mm spindle, but those effects are way outside of any practical difference. Would you like to estimate the 'crank heating' that's reduced by using these cranks?Except for in a carbon fiber crank, where flex indeed means lost energy. Buy mainly for higher frequencies than pedal frequency.
When it comes to axle flex, less is better, as it allows the bearings to be loaded correctly. I think this is where most of the stiffness of the EE Wings come from, a Ti axle will be twice as stiff as an alu axle of the same weight and diameter.
That's not possible, the material would have to return 100% of the energy given to it, which doesn't happen. Crank flex is probably a minute player in a complex system of the spindle, bottom bracket, chain and seat stays, etc. If all of these and the crank arm are flexing significantly, you probably are losing out on some significant watts that could be propelling you forward.Man I like the product. That video though...
..snip..
The old sugino, way-old shimano and cook-bros type stuff was where you got a lot of flex in the cranks.
..snip..
Badass, I used to want a Yo Eddy so bad.![]()
Here are my old Cook Brothers RSR cranks on my 1990 Fat Chance Yo Eddy with a Ti spindle. Flexy as a wet noodle but Super Cool!
So yeah, I agree it isn't 100%. Even a steel leaf spring doesn't return 100%. But in both cases it is really darn close. Are you disagreeing about the magnitude of the heat loss? Or some biomechanical disadvantage of flex?That's not possible, the material would have to return 100% of the energy given to it, which doesn't happen. Crank flex is probably a minute player in a complex system of the spindle, bottom bracket, chain and seat stays, etc. If all of these and the crank arm are flexing significantly, you probably are losing out on some significant watts that could be propelling you forward.
Once we moved to large i-beam, C-section and hollow-forged cranks, I think most of the flexiness issues went away. The old sugino, way-old shimano and cook-bros type stuff was where you got a lot of flex in the cranks. Once we went to octalink 1 we boosted the spindle strength and stiffness significantly. It's only gotten better from there, but those were the biggest improvements IME stiffness-wise.
I had those cranks on a klein I bought used. They were so sweet. I didn't mind the flex at all. Just looking down at them gave me power.Badass, I used to want a Yo Eddy so bad.
