1 - 1 of 1 Posts
Checking to see if anyone has had a similar issue. I have a cane creek DB Air IL and after removing the air car to install an additional volume reducer, the shock became semi "stuck". It won't move through its travel freely anymore, requiring a lot of force to push the shock through the travel. At 20 psi, the shock feels like it has more than 200 psi in it. Any thoughts about what the issue may be? The problem is the same even with the outer air can removed.
1 - 1 of 1 Posts
