1 - 20 of 25 Posts
While we all love the idea of a the angleset, it was limited to full 1 1/8" steerer forks...until April that is. Now all the tapered 1.5- 1 1/8" forks can share in the lovin! If they configure it the same way (up to +/-1.5 degrees) with an external lower cup adding 14mm of stack height , we should be getting closer to 2 degrees of change IMHO.
from Gary Maltby
to
date Thu, Mar 10, 2011 at 1:18 PM
subject RE: Angle Set for Tapered Steerer
Yup, it's in the works! Should be available sometime in April.
Gary Maltby
Cane Creek Cycling Components
800-234-2725
Sent: Wednesday, March 09, 2011 1:38 AM
To: [email protected]
Subject: Angle Set for Tapered Steerer
Any idea when an Angleset headset will be available for the 1.5 - 1/ 1/8" tapered steerer forks for the full 1.5" headtube? Rumors have it that one is in the works. Thanks.
Homer's problem child
Anyone know if CC has plans to make an angle set for tapered forks to fit tapered head tubes as well? I have a Mojo HD with a tapered head tube and would like to run an angle set with my tapered fork.
Thanks in advance,
B
Thanks in advance,
B
Jeeze I hope not. I just wish tapered anything would go away.
b-kul said:
As a clyde, I really appreciated the onepointfive system and all the stiffness it offers. Now it's not even available on the fork I want it on the most - the Float 180. With a single crown fork, there is a difference I can definately feel. Yeah I know motorcycles have small steers but they aren't single crown.
Elitest thrill junkie
The crown-steerer interface is where the flex happens.
Yes, yes it is "expecially" concentrated there when you don't have double triple clamps. It also happens at the stem/steer interface :D
Discussion Starter · #10 ·
Thanks in advance,
B
I'm sure they will, as it would use the already in production top cup for tapered headtubes...what was missing was the lower cup for the 1.5" headtube/steerer tube combo. You can/will be able to buy the parts as separates as well to make whatever you need.
b-kul said:
yes? ... not sure. if it is where the hell is the zs 44/44?
truf... at least put up a placeholder of one and state "coming soon" if it is legit. I like canecreek stuff, so I hope the 44/44 angleset is true.
meow meow
Terminator Z said:
New decline magazine has an article showing the 44/44 angleset on a 5 spot.
link/ pics? i actually want to see this, right now it is in the same catagory as bigfoot and aliens.
Sorry, no pics. I too am eager to get my hands on one of these, and am in desperate search of some real concrete info with pricing! You might need to cruise down to Barns and Noble and just check it out.
The article shows different configurations on different head tubes. The 44/44 is on a 5 Spot. The article even has a chart that tells what upper and lower assemblies to use. This one uses the ZS44/28.6 for the upper and a EC44/30 for the lower. The offset is in the lower external headset cup.
So I'm wondering if the added stack height is incorporated to achieve the 1 degree change? If not, it will add to the angle offset making it even slacker!
meow meow
the april issue? i'll just download it my computer. but im very excited to get one and get some more modern geo on my bike!
1 - 20 of 25 Posts
